Front and Centre LSD's
Has anyone got a front lsd fitted? How does the Quaiffe one compare? Do theh eat tyres but is it worth it??!! :slight_smile:
I don’t know who else has a front diff fitted aside from André.
When I had these installed I found grip out of corners to be significantly better.
The quaife diff is a torsen type so the application to the wheels is different. The Drawback with the quaife is that if one wheel has no traction the diff will not lock.
