Short lived
Thanks but i could end up buying an engine that’s worse than mine plus fitting costs out way the cost of the car and I could probably buy another car for less than fixing this one. if I get enough for this one I may just be on the lookout for another and this time any noises and I’m straight to the garage with it.
Hi before you buy please check everything and tell us if you find anything noises or you suspect something is not right.
We can help you.
All gtouk members can help you.
Hi Marinemma6,
Sorry to read this. Can you confirm that you or your mechanic retimed the crank and cams to their respective timing marks prior to checking the compression?
Yes re timed engine and no compression, so had definitely bent valves or worse thanks
