Water pump and timing belt change
HI good people,
I am looking to get a new water pump put in and new timing belt, tensioner etc done at the same time.
Can anyone recommend a reliable source for genuine strong parts? I have seen a few kicking about on eBay but not sure who to trust.
Thanks in advance
@GSXRKID at the Evil Empire will sort you out with those bits , definitely not worth scrimping on cheap parts where that particular job is concerned .
His details are in the traders section
Craig :grinning:
Genuine parts is a must for this job therefore Rob at Evil empire !
thanks will def get in touch.
From your experience how many hours can I expect on this type of job. My usual mechanic is “new school” and I feel like this car is not one to simply plug into a machine for timing purposes but will need someone to manually set valves and camshafts etc. My options right now are to trust him (worried he might be “experimenting”) or take it some 3 hours away to people that deal with them everyday.
any thoughts would be greatly appreciated
The job done properly will take around 4-5 hours
When you buy the kit from me you get the instructions and the tools you will need to do the properly and and much easier, which no one else does to my knowledge, plus you get the proper parts for the job too.
whist its not hard to do if your mechanic is the type who does not know how to use a spanner and common sense he may not be the best choice
Where about’s in the UK are you ??
HI Rob,
I’m in Glasgow. Have owned the GTO about two years. He is a good mechanic he has taken care of our family cars for a while now. Just that it’s the usual plug in and get a report then fix/replace something type of garage.
Inn the beginning the local Evans Halshaw wouldn’t even touch it for an oil change! I’ve been wary ever since
he’s not with EH by the way. he runs a small independent garage frequented by boy racers etc
Glasgow ,where you’ve been hiding ? I’ll send You a pm later :slight_smile:
ok PM me mate
any good mechanic should be able to work on a v6 lump no probs . as said above theres good how tos on forum if you need or I know a mechanic that can hep you out hes just doing same job to a gto this week .
scott
