Rear wheel
Hi guys my offside rear wheel looks to angle in at the top compared to nearside wheel ? had wheel off for other reason could,nt see any adjustable links unless im missing something car drives straight and true no issuse on road unless rear steer linkage is out ? whats your thoughts cheers for now.
Any uneven tyre wear ? Bet advisevfind somewhere that does a good alignment. My work has a computer alignment where the fit paddles to the wheels that have data points . So if you can find something like that would be good
Noticed this at nec. Kevin has wider wheels on his gto so was more noticeable. But when we looked closer all 3 gto’s there seemed to look like they had a bit of camber.
Jensen
Hi cheers no tyre wear just offside looks in at top compared to nearside looked under today no adjustment going in for 4 wheel set up soon just done spark plugs today not too bad had to set up ideal speed after but then all good…
