19” Alloys fitment
Hi guys i’m in the process of fitting 19” axe alloys to my mk1 gto but need some help
fronts are et40 8.5j which won’t clear front calipers so i’ve used spaces
rears are 9.5j et40 fitted without spacers
my concern is even though wheels sit flush with hub/disc, but there is slight gap in the centre bore pics attached, would this be safe ?
no spigot rings fitted. thanks
You need to measure the inner diameter and the outer diameters of the centre hole and then obtain some spigots that take up the difference between them
DO NOT DRIVE THE CAR WITH THE SPACERS MISSING ITS DANGEROUS
Ordered spigot rings 73.1-67.1
Hopefully they will sort issue out.
How thick are the spacers you used?
Spacers are 15mm
