Hi all
I’ve just had new propshaft bushes fitted.
(Refurbished propshaft). Now when I get to 60/65 mph, there is a tremendous shaking from the rear of the car. So much so that I have to ease off the throttle.
Any idea what’s the cause?
Derek
Did you replace the rubber bushings between car and bracket. Are the parts genuine mitsubishi?
Hi
I bought the bearings from Evil Empire.
I’ll check about the bushes tomorrow.
Thanks.
Derek
Were the mount spacers fitted in the correct orientation?
Bet they did not mark the prop shaft orientation, so it goes back together the same was as it was taken apart !!
Hi
Are there any diagrams you have so I can send them to the people who refurbished the propshaft?
They may show something if they’ve fitted it incorrectly?
Many thanks
Derek
Hi All,
The newbie section is for introducing yourself and your car only. Please do not post technical questions etc… in this section.
@derek if you wish to post in the technical sections of the forum you will need to be a full member.
