HI Rob, I have had a look round your web page, but can’t find the above. Can let me know prices please as mine are knackered.
THanks Dean
THanks Dean
they are in lighting…lol
http://www.evilempireperformance.co.uk/product_info.php?cPath=22_57&products_id=125
http://www.evilempireperformance.co.uk/images/MI-3000-I-CTC%20mk2%20Indicator.jpg
Loads in stock £35.00
call me on 01702-614469
Are they not indicators Rob? :?
dean, if it’s the long thin side lights you require that sit in the bumper, i don’t think rob sells them, as they are only available from mitsi main stealer!!!
He does sell them Paul, least he has in the past, had 2 of him so far at 2 different times, circa £28 (each) mark I think they were
yeah those are the ones I am after…I will give mits a call.
Cheers Dean
Rob should do them Dean, I’d hazard a guess at a good few quid cheaper than Mitsi too…
I do indeed have the side lights in stock.
Mitsi are a bit hit and miss on these, if they have them in stock or not
Give me a call if i can help you
[quote]I do indeed have the side lights in stock.
Cheers Rob[/quote]
Thanks Rob …PM me a price & I will call you next week to get them ordered.
Ta Dean
oooo i will have one too please rob, can you bring to the agm mate?
paul
paul, are you after one or a set as I Have the other one of the one that you have, if that makes sense, if you want it. Don’t think its water tight though.
Rob i need a set of these also if they are the long thin ones as you can see from the photo although mines a GTO i think previous owner has fitted these , i also need the elect connection as mine is goosed ill call you when i get back
Mo
i want a new one mate, i had new one last yr now the other one is leakiing and going green!!!
paul
Hi Rob, can you still get these? otherwise do you have a 3000gt mk2 chassis no. or the correct part no. so i can order them from mits?
Robin.
In stock and available
Just give me a call on 01702-614469
