5 speed gearbox
Rob - can you’re super-computer tell me what gearbox I have in my car - I think it’s an 18 spline output as you told me it came off production line 01.04.92? Reason I ask is because my gearbox casing is cracked/cracking and I’m going to need to change it (unless it can be welded up safely?) Your advice is always appreciated.
John
Hi John,
PM me your Vin number and i will reply ASAP
[quote]Rob - can you’re super-computer tell me what gearbox I have in my car - I think it’s an 18 spline output as you told me it came off production line 01.04.92? Reason I ask is because my gearbox casing is cracked/cracking and I’m going to need to change it (unless it can be welded up safely?) Your advice is always appreciated.
John[/quote]
Yes they can be welded if you get a good place.
I had some internal modifications welded into mine.
Cost £70 cash
John[/quote]
Cost £70 cash
Mark[/quote]
Thanks Mark - My mechanic thinks he may be able to get it done by a race engineers locally - if not then Sumiyaka have offered to do it.
im searching for a 3 speed cortina gearbox to put in a speedway racecar… can anyone help me out?
http://fix-error.win-help.info/Runtime-errors/runtime-error-50003-load-report/
