Hi Rob, i am still trying to track down the 2 rubber seals that go on the ac condenser, after Mitsubishi Tunbridge Wells sent 3 different types at a cost of 79p a go they still failed to get me the right ones. It looks to me that they might be shaped like a copper olive might look in the way of conical. If you look at a condenser its the 2 seals that sit in the flat plate that the flow & return pipes bolt onto. Do you think you would be able to get these for me. 1997 UK 3000GT. I look forward to your reply, regards Bob.
Hi Bob
Will look into this for you again and see if we can sort it.
Most of the Air-con spares are no longer available now…
