I have a brand new in box AEM Infinity Series 3, any ideas what I should be asking for it? I paid wholehearted too much for it and I can’t find anyone that can make the patch lead required to actually use it so I’ll be selling it on, curious if anyone’s sold one & knows roughly what to be asking for
Im looking at getting a lead made for mine, same situationas you, I just need to find the pin diagram for what I need (ecu and where i need to make wires to) and the connector to the ecu as i know rob use to have an adapterso you didnt chop any wires on the ecu itself, If anyone can help with wiring diagram, I will see how well it goes.
I have seen marty k had a patch harness, not sure if he’s still making them and I know it’s not for the standalone side
It would still be worth a chat with @Marty_K ![]()
I am certainly still doing patch looms.
One left until new stock arrives
I can also do loose connectors and pins, if that helps. Can also do wired up connectors with a length of wire, ready to connect to the aem ecu connector. You would have to source this.
I have plenty of connectors in stock. But only 1 complete patch loom at the moment
Hi Marty
could you make a wiring loom for an Infiniti 5?
I would also be interested in an infinity 5 loom if you are able to do so
Sorry, but I have no plans to make specific looms
Not sure if it will help b6ut I spoke to a company near me and they said they can make a custom harness for aem ecu and for the gto, they also said it will be around £800
Good work Jason, do you think they would be interested in a group buy if we could get a few ppl together? Probably 4 or 5?
Not spoke to the company, still ages away from being able to take my car to get a harness made, but i did find out from Facebook group that all infinity ecus use molex m123 connectors and these series 3 are 73 pin.
I know it’s not a ready made harness but it gives you the connector, this was the bit I was worried about the most
I am in discussion with Redline at the moment about getting some looms made up. As already mentioned they have estimated the cost at around £800.
What will help the cost is if we can get an idea of how many we need to get made up.
I need:
5x infinity 3
1x Infinity 5
Mines an infinity 5 so add me on the list
Mine is 3, you can add me to the list
Infinity 5 for me please
