Auto gearbox oil - what kind
What auto gearbox oil should I put in the GTO? The leak I mentioned is coming from the autobox somewhere but the garage can’t see where as there I loads on gearbox oil. Would I use dexron 2 or dexron 3 autobox fluid? I got some from Halfords today just in case and it states it is compatible with Dexron 2 and 3 as well as a vartiety of other engines including Mitsubishi?
Also, i checked the Gearbox fluid before after i parked up. I’d been out for a run (8 miles) and The engine was still warm. With the engine running i checked the level, wiped the dipstick and put it back in and the fluid was halfway up the dipstick? I presume it should have been in the part that has the s type bend?
If the fluid is overfilled, could this be why its leaking? If so, where would the fluid be purged from?
Any help appreciated.
Peter
