Sadly I think I’m going to break it, I need to find some funds to hopefully buy a red one that is up for sale
I’d like to keep the interior ideally as it’s the best I’ve seen yet (unless I get a very good offer), the brake components, the exhaust and the radiator.
The engine is essentially brand new, was rebored with oversize pistons from Rob, reground crank and flywheel, head skimmed and valves lapped in properly. Also new knock sensor, crank and cam position sensors and obviously the cam belt. It has only done 16 miles since the rebuild and passed the MOT easily on emissions. One negative is the aux pulleys are a bit loud, but I’ve got replacements to go on.
I’ve also got a very good condition red sunroof with only a small blister on.
The ECS and ECU both work fine, the gearbox is a 5 speed and doesn’t grind in any gears, though does have a crack around the filler and the output splines are getting a bit pointy.
The doors are good, couple of dings, and the boot lid has a small amount of surface rust. The aero worked last time I tried, though the front tray is ropy.
Weather seals aren’t great, windows are a bit scratched
Sorry to hear this. I was very near to breaking mine but glad i didn’t. Love the GT in black. It must be in a very bad way for you to make this decision. Just make sure the red one is not in the same condition James.
Yeah, it’s got rust in both floors, up the seat boxes and in all of the sills. I’ve got no spare funds at all at the moment to do the work so it’d be off the road for a long time, so I think this is the right decision.
Plus the rest of the car is just as tired as the bits that need the welding doing, so I’d spend $$$ on the welding and still have a tatty tired car
Ok, the one I was going to buy didn’t work out, so I’ve decided to strip everything off it. Some stuff I don’t know prices, and other stuff isn’t on the list yet.
I’d like £3k for the engine ONO. I’ve spent more than that on it, it has had
turbo oil pipes
cam sensor
crank sensor
acl bearings
thermostat
water pump
oil pump
knock sensor
iridium spark plugs
brand new, oversize pistons
ignition leads
seals
cam belt
head gasket
Right, hopefully my table works! Let me know if my prices are unrealistic, I’ve struggled to price some stuff.
Part
Price
Postage
Condition
Rear Lights (each)
75
10
Good
Centre 3000GT garnish
50
10
Some surface marks
Rear bumper
100
Some scratches
Boot lid inc aero and plastics
150
One rust blemish, other than that good
Boot plastics
20 each piece
10
Good
Fuel tank
90
One bolt missing from fuel pump attachments, surface rust
Rear hubs inc ABS sensor
30 each side
20
Rusty disk shields, abs sensor not tested
Diff
220
250
Surface rust, good condition
Black interior inc leather seats, door cards and carpet
800
Very good condition, virtually no wear. Black carpet has marks where foot rest used to be. One scratch on rear seats
Air con screen
Good
ECU
200
20
Good
ECS ECU
25
5
Good
Loom
Un cut and original
Steering wheel
100
10
Good, couple of marks
Dash clocks showing 90k miles
130
20
Good
Leather handbrake and gear gaiters with purple stitching
15
5
As new
Rear subframe
30
Cleaned up and started painting, no bushes
Purple brake pipes
100
10
Front fitted but new, rear brand new
Stoptech rear discs, slotted
180
20
Brand new
Stoptech front discs, slotted (larger ones)
150
20
Fitted but new
Stoptech rear pads
50
10
Brand new
Front calipers, purple (larger size)
150
20
Very good condition, no corrosion on pistons
Front calipers, unpainted (larger size)
100
20
Pins stuck in them, probably some corrosion
Mishimoto radiator
200
20
New but fitted
Evil empire oil cooler kit
200
20
New but fitted
Front lights, black plastic
90 each
15
Polished and good condition, but needs another polish to be perfect
Wheels and good tyres
200
Wheels painted badly, tyres good
Engine mounts- genuine Mitsubishi
250
20
New but used
Front brake disk shields- genuine
50 each side
10
Brand new
Rear steering pipe guard (plastic side)- genuine
35
10
Brand new
K&N panel air filter
35
5
New but fitted
BC Coilovers
680
20
Brand new in box
Gearbox (5 speed)
400
Needs repair to filler and splines have some wear. Gearbox drives nicely though
Transfer case
200
20
Some wear on splines, painted black (not a bad job)
Starter motor
40
15
Good, one screw head is stripped
Alternator
40
15
Working fine, bearings could be smoother
Front hubs inc ABS sensor
70 each
20
Partially painted but scruffy, ABS sensor included but not tested
Wing mirrors, non folding but heated
40 each
15
Scuffs on them
Prop shaft carrier bearings genuine Mitsubishi
190
20
Brand new in packaging
MAF
Blueflame stainless oval tip exhaust
680
20
New but fitted, some scratches on
Rear subframe mounts- genuine
55
Brand new, still in packaging
3000GT Catalytic convertor
GTO Catalytic convertor
Clutch
100
20
Genuine new clutch, fitted and driven 16 miles but new
Yep, you can have them. I’m between Ashbourne and Derby, but my parter works in Stafford if that’s any use. Do you want the arms too or just the hubs? Arms are a bit ropy.
No, sorry I’m going to sell the engine all as one if I can
Yes, you can have all of those, though the transfer box may already be sold, I’ll let you know.
Please read the descriptions of stuff, I don’t want people to get the wrong idea about condition. I’ve got pics but will only put them up if people want them, as it takes 15 mins per picture to upload on my Internet!
