NB. IF ANYONE BELIEVES THEY ARE WAITING ON ME FOR A RESPONSE / PARTS PLEASE PM ME.
After much contemplation and consideration I have decided to break my modified Mk1 TT. All parts are available but the vehicle has some modified parts fitted that I will list here in the next couple of days but to kick things off:-
7" single din motorized touchscreen. Bought from b-billion ebay shop about 4 months ago. Tested fitted but never used. £130.
1x Odyssey 925 MJT(Metal Jacket) batteries £50 each.
1x Alloy battery bracket with Stinger battery clamps and fuses as shown.£50.
Greddy fully automatic turbo timer with plug and play wiring harness. £35. Sold.
Pair of 13T turbos ( have done around 3000 miles ). £500. Sale agreed.
Set of 580cc injectors ( have done around 3000 miles ). £200.
H4 Hi/Low HID bulb kit 8000k with ballasts / wiring etc. (this has been fitted to the car and used on a handful of occasions). £40.
Sold.
HKS Downpipe generally good condition. £150.
Stainless adjustable decat pipe. £65.
Recently refurbished starter motor. £50.
Nearly new PTU. £75.
As new door top trim. Around a year old but in excellent condition. £70. Sold.
Three gauge pillar pod. £45.
CAS all electronics recently replaced. £50.
Set of 8.5mm MSD plug leads. £35. Sold.
Twin Turbo ECU ( has had caps replaced ). £200.
Alternator. £45.
Samco radiator / coolant hoses. Both have alloy adopters to fit sensors for temperature / pressure gauges. £50.
Plenum spacer. £20.
AEM Wideband 02 sensor and gauge. £125.
http://www.aem-power.co.uk/aem_uego.htm
Autometer UltraLite DPIC gauge. £50.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3293
Autometer UltraLite boost gauge. £30.
http://www.autometer.com/cat_gaugedetail.aspx?gid=3150&sid=11
Autometer Ultralite oil pressure gauge. £40.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3099
Autometer Ultralite oil temp gauge. £45.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3468
Autometer ultralite water temp gauge. £115.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3134
Autometer Ultralite clock. £60.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3106
Autometer Ultralite voltmeter. £35.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3111
Autometer Ultralite pyrometer. £110.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3290
Mk1 undertray. Virtually brand new been on the car for around 100 miles (has a few very light surface scuffs on the front edge due to a low kerb to access my house). This cost me nearly double what I am asking for it. £200.
Set of 4 lightweight locking wheel nuts ( Standard non tapered fitment). £15.
Oil catch tank in blue. £25.
Powder coated cruise control cover. £15.
Fuel injector harness and multiplug wiring cover( left side of plenum ). £30.
HKS SSQV dump valve with recirculating or atmospheric fittings. £95.
Set of tailored mats with mitsubishi checkerplate heal plates. £30. Sold.
Powder coated rocker cover. £30. Sold.
Pair of powder coated radiator mounts. Never fitted. £25.
Mitsubishi tax disc holder. £5.
Pair of polished alloy door handle backings. £20. Sold.
Complete custom leather interior. Including seats, centre console( complete with gear and handbrake etc. Gear lever can be wired to illuminate blue when the lights are on), steering wheel, Rear pannels, Door cards( The GTO inserts illuminate blue when the lights are on). 1 slight scuff on the drivers seat but will probably not even be visible with a bit of blue shoe polish or equivalent applied. £500. Provisionally sold.
If you can collect then that would be prefereable. Due to the size / weight of some of the items shipping costs could be expensive. I can probably deliver in the greater london / south east area for the cost of the petrol.
I will be listing other parts and uploading pictures in the next day or two. Meanwhile if you have any specific parts you need let me know and I will see what I can do. Small / light items can be posted at cost.
Best regards,
Damien.
