Broken wing mirror
Hi all,
This morning with my immobiliser fiasco I knocked my drivers side wing mirror and it has fallen off. It appears to have been glued previously by the previous owner and was wondering if there is a part I can buy to fix it or if I need to buy a whole new wing mirror? Is it possible for me to remove the who thing and if anyone knows of a link for where I can see how to?
I’ve never had to remove the mirror but I would have thought it would be as straightforward as removing the door card to get at the bolts which holds it in place. I would say it’s going to need replacing.
Good luck
its even easier those 2 rubber caps cover the bolts there captivated nuts so you just have to undo them the loom pulls up enough to disconnect it
mark
As mark said you can see the 2 bolts in the last picture you put up. When it’s not broken you just have to fold the mirror and you can see them.
@markie1978 @GSXRKID thanks guys have a new one on order now so should be all good will send update pics once new one is on.
thanks again
Richard
did you order new ??
well… second hand but in amazing condition.
Phew !!!
A new one would be a tad dear from Mitsubishi !!!
