Recently forayed into the world of the GTO with the purchase of a '90 twin turbo. It’s currently up on axle stands with the rear axle dropped out for some TLC, but I look forward to getting stuck in once I’ve put it back together!
Thanks for the welcome all!
Max, it’s not the original paint no, she’s been re-sprayed (same colour) - looks to be a fine job though.
I’m just outside Ely Matt, so well within half an hour from you.
Must say, i haven’t seen one around these parts for a long long time; glad to see mine won’t be alone! I hope to have it up and running within a couple of weeks. Am intending to give it the once over, and probably disconnect the rear wheel steer while I’m at it.
Hi you lot
I am in Feltwell , mine is on axle stands as well at the mo , The gearbox is out I took it to a track day and I must have gone into reverse ,when I was going foward ,subsequently no reverse anymore , 9 hours it took to get the box out , prior to the track day my gto had been sat in my garage for 9 years , so I think a full overhaul and big service is due ?hopefully back on the road by the end of august All going well ? ? ?
Often seen grazing on the Evil Empire forecourt , very very occassionaly spotted on the camping grounds of GTOUK meets , normally occurs the same year the queen actually smiles
