Carbon effect vinyl Sail Panel inserts available for pre 1999 cars. They come as a pair cut to size along with a squeegee to let you fit them accurately.
This is the test sail panel:
http://www.undergroundgraphics.com/tmp/IMG_1615-sm.JPG
Other images can be found in http://www.gtouk.org.uk/phpBB2/viewtopic.php?p=3565490#3565490 or more http://www.gtouk.org.uk/phpBB2/viewtopic.php?t=33195&start=0 [scroll almost to the bottom].
Ordering Info
Cost is £14.95 + £2.95 for first class recorded shipping. Add £2 if you want a pair of ‘Twin Turbo’ logos to go on top - your choice of colour. Custom logos available on request.
As usual, a percentage of the sale will go to Club funds.
Please email chris /at/ undergroundgraphics.com with any queries or to place an order. Prefer email over PMs as they are easier to track and less prone to getting lost or missed.
If you make a purchase please reply to this post so the Club know to expect a payment from myself.
Fitting Instructions
- ensure the sail panel is perfectly flat - if the lacquer is peeling you need to flatten this first
- ensure there is not dirt, grease, dust or fibers on the sail panel - fitting the vinyl on top of this will result in it not sticking [if its greasy/dusty] or little bumps showing through
- soak the sail panel and sticky side of the vinyl with water
- position the vinyl in the correct location, lift off and apply again if you get it wrong or you may be able to gently slide it into position
- use a soft rag/kitchen towel over the plastic squeegee and firmly work the water out from under the vinyl, start in the centre and press to the outside
- wait a bit for the glue to adhere then apply your Twin Turbo / GTO logos if you opted for them
