Hi All
I have a 1993 manual GTO with a sticky clutch. I can’t get full travel to the bottom of the car unless I push 2 or 3 extra times. Also, it makes awful sound which I can only describe as coming from a demented chicken.
Can these clutches (hydraulic) be adjusted or is it a case of a clutch replacement?
Thanks in advance.
Hi @derek ,
This is another post relating to a technical issue in the newbie section.
If you wish to be part of the forum and receive/ access technical support and information please consider signing up to full membership.
This post thread is now closed.
Club Secretary,
