Originally posted on Aimoo, http://www.aimoo.com/forum/postview.cfm?id=308930&CategoryID=19539&startcat=1&ThreadID=185113
[quote]My mk1 is running Pilot Sports in that size, I’ve found 30 rear and 32 front seems to work ok, though fronts still look a bit flat.
Regards Austin…[/quote]
[quote]Im running 34 psi rears and 36 psi in the fronts, but just check the wear on your tyres to see if the wearing on the outsides ( not enough pressure ) or wearing in the middle ( to much pressure ). The low profiles will make them look flat, mine still do running the psi as mentioned above.
Martyn ( YELLOW TT )[/quote]
[quote]The standard pressures are 29 psi rear,32 psi front.I run mine at 28 psi all round and wear and handling are fine.This doesn’t mean that this pressure will suit other tyres/drivers.It’s mostly a case of adjusting a bit at a time and find your own suitable pressures.As Martyn points out be aware of the tread wear pattern as this is probably the best guide to correct pressures on a non standard set-up.
Mark.[/quote]
