Hi i have a set of mk1 electric mirrors in fiji blue will probably need a respray make me a offer if anyone is interested
pete
pete
i remember the day when these were like gold dust once
pete
Is there much work in fitting these if you dont already have folding mirrors?
Not too bad since you are RHD. You will need to run a few more wires though. Getting the wire harness with them helps.
Hopefully you also got the matching mirror control switch and the 2 control boxes for the system.
only the mirrors nothing else
pete
Pete, are these standard mk1 mirrors or are they electric folding?
Hi Smudge, yes electric folding 7 wire plug, but dont have any wiring etc
pete
[quote]Hi Smudge, yes electric folding 7 wire plug, but dont have any wiring etc
pete[/quote]
You dont need the loom with it unless you want them fitted via its correct switch, I fitted these twice to 5 wire plug versions simply to fold in using the c/locking pulse in the door, no wires to run apart from wiring up a couple of Latching relays. If anyone is going to do it i have a wiring diagram showing exactly what to do.
Julian.
pete[/quote]
Julian.[/quote]
cheers julian good info there
pete
still got these?
No he hasn’t. Because I have them
