Hey Rob did those hosees come in that i have orded off you if so what is the ETA on them. Thanks for the brill job you are doing. look forward to hearing from you. Thanks again
[quote]Hey Rob did those hosees come in that i have orded off you if so what is the ETA on them. Thanks for the brill job you are doing. look forward to hearing from you. Thanks again
Dann[/quote]
Hi Dann,
Your should be into me tomorrow, will give you a call later in the day
