The engine package is in pieces, but all that is written down is included.
Forged pistons
Bored block
Reground crank
Complete bearing set
Almost brand new oil pump (needs a wash out!)
All of the required gaskets
Other parts:
Heads removed from 40 mile old engine (big end failure due to incompetent engine builder…) skimmed and valves cut and i just fitted new stem seals
Pair of Tarox rear discs (They did about 2 miles!)
Full set of tinted lights (tinted mk1 centre garnish included)
Pair of GOOD second hand turbos from a mk2 GTO
Mk1 ecu (rebuilt by the ECU doctor in the past but un-sure of when! Car ran without fault)
2x Coilpacks
1x PTU
Pair of new bottom ball joints
Pair of new track rods
New gates timing belt
New fuel filter
New oil filter
New spark plugs x6
Knock sensor (used but full working order)
Standard plastic y pipe with a good rubber!
Mk1 crank pully (has a slight chip on the edge)
HKS mushroom air filter
K&N air filter
Pictures to follow this evening. Offers!
Thanks, Josh
Hks dual exhaust
Almost new rad
Sparco flash 5 steering wheel
Most likely more to but I cant remember!
Rear tinted lights (Can compare them to the GTO on the left. I masked the reflectors/reverse lights off for the most of the tinting and then put a very slight tint on them. This makes them LEGAL and to be able to pass MOTs)
Steering wheel (centre section is polished even tho is doesnt look it in this photo!)
Heads
Pistons
HI MATE , IS EXAUST STILL FOR SALE, IS IT DECAT AND HOW MUCH THANKS,SIMON
ad087
April 5, 2011, 3:54pm
#10
How much are you looking for for the heads if they are still available?
hi how much you looking for the short block as a unit
Heads are still for sale - There are a pair of used ones on ebay for £100, so £120 + postage?
Short block - £550 + how ever it will be transported! (Please note that it needs assembling!)
crizdee
April 11, 2011, 10:50am
#13
Most likely more to but I cant remember![/quote]
Hello,
Did the car have an active front aero?
I’m looking for the long metal rod and brackets that move the aero up and down.
My rod has bend and one of the brackets has ceased to the rod and won’t move!
Chris
brett
April 13, 2011, 2:19am
#14
HOW WE DOING ON THE LIGHTS MATE IM READY WHEN YOU ARE MATE
