We have finally had the first delivery of our new engine coolant and breather hoses for the 3000GT and GTO engines I have had made arrive.
These are perfect copies of the Original Mitsubishi Hoses and fit exactly. Most of these hoses have been unavailable for many years from Mitsubishi and have now gone hard and now no longer seal properly.
I have made them available in three colours as I know lots of you like to colour co-ordinate your engine bays, so they are available in Red, Black, and Blue
Another feature is that the Hoses are all the same colour through out so you don’t see any other colour when there fitted on the car like some other manufacturers ones do
To order them go to my website link below
https://www.evilempireperformance.co.uk/
Currently available and in stock are:
Front Cam cover PCV Hose
Front to Rear Cam cover Link Pipe Hose
Rear Cam cover to air Intake Bubble Link Hose
Heater Matrix Hose Kit
6 Speed Gearbox Radiator Hoses (Mishimoto and Samco are Designed for only the 5 Speed cars)
Throttle Body Heater Feed and Return Hoses
Available shortly Due before Christmas
Brake Vacuum Assist with Metal One way Valve and 1x Link Pipes
Clutch Vacuum assist with Metal One Way Valve and 3x Link Pipes
If there is enough demand for the NA only hoses I will have them made too, just let me know if your interested in them and if there is enough demand I will get them made.
Pictures of the pipes are below for you to look at.
