Not really as Mark needs the results to trace where the problem is.
If anyone else wants to ping or tracert the site here’s what you do if you’re running Windows:
From the desktop, click start
Select Run
In the Run box, type command
Click OK
The DOS window will pop up. At the C:\WINDOWS> prompt type ping www.gtouk.co.uk and press enter.
You will see some results pass through the screen.
It will tell you if there were any packets lost in the transfer (0% loss is what you want to see).
8 ) It will also tell you the average speed, in milliseconds.
To close the DOS window, type exit at the C:\WINDOWS> prompt and press enter.
To Tracert instead of typing ping and then the web address you just type tracert
You can type your results or as me you can print screen and post up the image.
mine was running like shite so I changed to gtouk.org.uk and everything was a lot better. Is that the right address or not as I was using gto.co.uk before and it kept chucking back errors etc.
Pinging gtouk.co.uk [80.71.3.150] with 32 bytes of data:
Reply from 80.71.3.150: bytes=32 time=31ms TTL=55
Reply from 80.71.3.150: bytes=32 time=32ms TTL=55
Reply from 80.71.3.150: bytes=32 time=30ms TTL=55
Ping statistics for 80.71.3.150:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 30ms, Maximum = 32ms, Average = 31ms
Select Run
Click OK
You can type your results or as me you can print screen and post up the image.[/quote]
You can also right click on the black box, pick mark, then select the text you want to copy, then press enter. This will copy the results into the clipboard so you just paste them into here with ctrl+p
Pinging gtouk.org.uk [80.71.3.150] with 32 bytes of data:
Reply from 80.71.3.150: bytes=32 time=27ms TTL=55
Reply from 80.71.3.150: bytes=32 time=29ms TTL=55
Reply from 80.71.3.150: bytes=32 time=26ms TTL=55
Minimum = 26ms, Maximum = 29ms, Average = 27ms
Pinging gto.co.uk [206.123.69.38] with 32 bytes of data:
Reply from 206.123.69.38: bytes=32 time=132ms TTL=50
Ping statistics for 206.123.69.38:
Minimum = 132ms, Maximum = 132ms, Average = 132ms
sorry to add this.but you may have seen my reply for the sale of a decat. well i had to keep refreshing to make sure i had first bids, was absolutely slow.
It’s funny because the forum is running ok for me, only had it hang a couple of times earlier in the night but no other problems since.
Just done another ping test
