Front aero
Hi rob,
Just wondering how much for a front active aero motor and spoiler.
I may just make an interface box and not use the front aero
regards
Nigel
Hi Nigel,
The front and rear aero system definitely has an effect on the cars when you use them at high speed.
Do you have any of the parts of your left?
I will be breaking a GTO TT very soon that still has the Front Aero still intact on it. This would be a better beat as the tray alone is £350 from the Empire (£500 from mitsi UK) I have not dared to ask how much the aero motor gear assembly is as I know this is nearly £900 in the UK.
Let me know if I can help you
i know complete rear aero and working fine, but i do not have the front one.
I know i dont have the front motor and spoiler but there is still a bar going across the front with brackets on each end. I will have to look closer if you need more info
regards
nigel
