Walbro 255 LPH (when wired to receive 13.5 volts) High Pressure Fuel Pump with fitting Kit, includes new filter screen, sealing o-ring, noise reduction sleeve, wiring loom and fitting instructions.
http://www.the-evilempire.co.uk/images/Fuel%20Pump%20Kit.JPG
Fits all years and models 1991-1999
As soon as you start to tune your GTO or 3000GT you will need to supply more fuel to the injection system as the engine demands more fuel when you increase the power output.
This pump is the normal replacement to archive this goal, used by tuners the world over, This Walbro pump delivers reliability and dependability.
Pump including Fitting kit £90.00 +£10.00 P&P
Pump and 13.5 Volt Relay Hotwire Kit £105.00 + £10.00 P&P SAVE £5.00
