GTO and 3000GT Track Rod End
Hi.
Can you tell me if the ‘GTO and 3000GT Track Rod End’ that yoiu sell is the same for front and rear (4WD) and if so, do you do a deal for 4?
Thanks in advance
Aidy.
also do you sell the other bit for adjusting the rear alignment which is a cam adjustment point if you know what i mean. gonna have a look at the manual in a short while so should be able to tell you what part i mean.
Aidy.
Oppps :oops: :oops: :oops: :oops: Missed This Post
Give me a call and we can sort something out.
We stock both Front And Back Track Rod Ends.
And the Camber Bolts.
07891-606913
