Mine has the orange indicator lights. These can be changed for clear ones.
I also have the clear strip on lower bumper. These where an extra. Mine can be turned on alone as running lights, or with the front fog lights, and then with normal lights as well. I think Graham had a set for sale on his site.
Hope this helps.
Jensen
so just to be clear, when you run your main lights the clear strips on the front light up (and the orange ones don’t?)
I am new to this forum please show me the website link so I can check out the lights
I don’t know if this is the correct setup.
This is just how mine are. A more knowledgeable member might be able to give you advice on how they should be. But as far as I know your orange lights should not be on constantly. They are indicator lights.
Jensen
