Beyond putting back on the road so @LukeGTO is breaking this, please pm him for part’s.
Thanks Dave.
Could do with the door moulding that goes down the drivers side a pillar fella , the external piece
Dibs on complete throttle body assuming in full working order,dimmer switch if clips not broken.
I will check the condition of the door moulding for you tomorrow
I can only assume the throttle body is in working condition, I will clean it up and try it on my running gto first, I will check the dimmer switch tomorrow too
The dimmer switch is in one piece, well till you touch it
Depending on the price I might have dibs on the boot lid if it’s in good condition (and fits a mk2) and the front chassis members if they are straight.
Might have to wait till next month to pay though
Cheers mate
Most important is the idle control valve that works and throttle position sensor.
Also is the gearbox 25 spline?if yes what’s the condition of it?
Climate control unit working ?
I will remove the climate control and try in my gto to see if it’s working ok
Removed and in one piece ( i removed it lol )
Is the CAS unit still on the engine ??
If so, i will take that
Yes the CAS is still on the engine, will remove it this evening/tomorrow. Not entirely sure how much they are worth so open to offers
Payment sent cheers @LukeGTO
As I said on fookbook it’s the proverbial rocking horse ■■■ .
Get new weather strips in otherwise they will soon be scratched
I meant the strips lol in one piece, from what i can see on these Windows it is the internal door glass holders that’s damaged theses Windows, are you still drunk @CDMH
Probably lol
Condition of bonnet please? And where are you?
Condition of bonnet looks ok just needs a good clean! I’m located in Norwich
