Headlight beam benders
hi. I’m going for my trip to Europe and bought some Headlamp Beam Adaptors/ Beam Benders but fitting instructions not covering 3000GT or GTO. Anyone had those fitted ever? i will also need those fitted for my new car from the states for its first MOT they say. hope you can help
Are you referring to the adjustable height aiming requirement on these cars in the UK?
I dunno anything about it. I went to MOT station and they yold me told me to use those stick-on beam benders instead of replacing headlights, and they will MOT it. I have bought some headlights from Damien just in case i have a problem
I never heard of those but since you bought new headlights that would be the ultimate fix. If they are the electrically adjustable kind you will have to find a spot for the switch though.
AM i missing something this is a import car from the States with left hand drive headlights so wont need changing to drive in Europe. Would need right hand drive headlights for the UK MOT Test? Best wishes Phillip (Silver Surfer)
Hey man, where are you stationed at? And it all depends on what kind they are and if you have the mk1 or later model. Its fairly simple and it should be pretty general putting them on. Just follow the instructions it says for any other car and you should be set. Or you can pay a garage somewhere to re-adjust the headlights for you so they aim to the left instead of the right.
