Hi everyone
Hi everyone new the site, I was also going to ask if anyone could help me with whats the best gearbox oil to use for the 1994 gto non turbo? because i heard some oil are good to cure the common 2nd gear grind which i also have only when i downshift from 3rd to 2nd gear at 15mph above, any help would be greatly appreciated.
Hi and welcome to the club. Hope someone can help you with your problem I have the same issue with third so would be great to know the outcome. Hope to catch up at one off our meetings. Jon
If you use 75W90 GL4 gear oil. This is the one that it recomended in my Mitsubishi workshop manual .
2.4L Gear box
0.27L transfer box
Welcome to GTOUK :smiley:
Julian
Hello and welcome to GTOUK,
Welcome to the club
There’s a partIcular one for worn syncros etc but I can’t remember which one it is, I’m sure rob will post up,when he sees. Worked a treat for me.
These cars are renowned for some “baulking” when shifting up from 1st into 2nd, and particularly when shifting down from 3rd to 2nd. A 75W-90 GL4 oil is the recommended one for these gearboxes. Real difficulties in shifting without crunching indicate wear, which will most likely involve replacing certain parts.
Good luck with it,
Thanks everyone for all their warm welcome greatly appreciated and also for their help regarding the gearbox oil.
Gavin.naish yeah that would be great if Rob could tell me which oil it was, it would be great to fix this :slight_smile: looking forward to hear from him hopefully soon
Thanks again everyone
Hi fella welcome to GTOUK 8)
If I was ever going to get another GTO as a daily driver then an N/a manual would be what I would be going for 8)
Craig :slight_smile:
I’m sure it was this one
http://evilempireperformance.co.uk/gto-3000gt-shop/index.php?main_page=product_info&cPath=95&products_id=474
It was a long time ago, I always had a crunch when changing around 2nd gear. Seem to remember it felt a lot smoother and solved the problem. Of course since then I’ve changed oil again but can’t report any problems, maybe it was because my gearbox didn’t have any oil in it in the first place!!!
Welcome to the club. Is the issue constant or only when the gearbox is cold? I have trouble shifting 1st and 2nd at first but when driven for a bit and the car warms up it disappears.
That oil will help that too. :wink:
Welcome to the club
thanks again for all the warm welcome, nice how come the manual non turbo?
Its more when the car is cold and i get it when downshifting from 3rd to 2nd gear, usually at 15mph or more.
Oh ok thats great i will get it and change the oil soon thanks for your help :slight_smile:
Hello and welcome. Glad the guys are all helping already… Generally that’s how it is here :slight_smile:
Hi thank you :slight_smile:
Yeah but i am trying to see where i can buy the titan gear syn, i could only find in on ebay , coudnt find it in any local shop!
Gavin did point you in my direction earlier in this post…
http://evilempireperformance.co.uk/gto-3000gt-shop/index.php?main_page=product_info&cPath=90&products_id=602
We stock Titan gear oil and do a complete Kit which i must add a NA one as the fillers and drain have a different thread to the Turbo cars…I il do this on Monday
If you order it add your cars Vin Number so i can make sure your get the right filler and drain plugs or call me if you wish on the numbers below next week and i will look after you
Hi Rob ok thank you :slight_smile:
I was also wondering what type of power steering fluid do i need to use on my 1994 non turbo because i need to fill the power steering fluid up it a bit low?? Any help would be greatly appreciated
