HKS EVC 5 Boost controller
For Sale: HKS EVC 5 Boost controller.
Is going to be removed from my car in the next few days by Pete at Evil Rob’s unit as i’m going Maft Pro direction.
*HKS’ all-new EVC (Electronic Valve Controller) is the first boost controller to feature integrated CPUs in each component (Display Unit, Control Module, and Stepping Motor) for more precise control, quicker response and improved boost pressure stability.
This race proven system is available in KPA measurement and features an easy-to-read LCD panel that can be positioned separately from the control module for driver convenience.
Feature and Benefits:
COMPACT DESIGN The new 1⁄4 DIN control unit, 1⁄2 DIN display unit and stepping motor are all compact in design, making for easier installation and mounting inside the ****pit and in the engine compartment.
DIGITAL AND ANALOG DISPLAY The digital display shows real time / peak hold measurements while the adjustable range analog bar graph helps with intuitive perception of boost levels.
WIDE SCREEN MULTI-DISPLAY A reverse illumination white display allows for improved visibility in various lighting conditions. The display shows multiple measurement readings for on the spot data confirmation.
INTELLIGENT STEPPING MOTOR A CPU is imbedded into the stepping motor. This creates more direct and accurate control as the CPU virtually eliminates lag time between the stepping motor and control module. Thereby increasing linear boost control and stability.
HIGH BOOST CAPABILITY A wide range of boost control is possible, from stock boost all the way up to 250 kPa (2.5 bar / 36.25 psi).
EASY BOOST SET-UP 2 individual boost levels can be easily set by simply turning the volume knobs of the control module.
2 MODE BOOST SETTING FUNCTION Separate A and B boost level settings can be tuned according to the user.*
I had my display on a phone holder thingy near the radio, and the unit with the A and B button fits well underneath the armrest :
http://img3.imageshack.us/img3/1058/img0859wx.jpg
[size=18]£ 225, including recorded delivery.[/size]
[size=24]Price drop £ 199,[/size]
