Hi can someone were to find bleed nipples and how to bleed clutch on a 3000gt thanks
If you look on top of the gearbox you will see some bleed nipples attatched to the valve , probably easiest if you remove the battery and y pipe
If your going to do that and it hasnt been done before its worthwhile upgrading the clutch flexi pipe to a stainless steel braided item
Ok thanks I will look someone did say there was 1 on the slave and 1 under the air filter
Clutch all done and working well
Good to hear fella
