Inner arch and undertray?
Hi Rob,
When you have a minute can you find me a price for an inner arch for the front right and an undertray (just the small front right hand side part below the intercooler) for my '96 MR?
Robin.
Almost forgot, I need about ten of those strange push in screw out black plastic clip things as well… Cheers!
Hi Rob,
The undertray is part number MB935455 (says on it!) the inner arch is the front lower front right inner arch, which clips to the undertray above, which I haven’t got a part number for. After taking it all apart I now also need 8 of the bolts that hold the bumper on along the bottom (the 10mm ones with the collar for going through the plastic bumper) These were missing, as were three of the bolts holding the bumper to the wing (the really fiddly to get at ones under the arches, also 10mm) and I still need the silly clip things which hold the inner arches on…
I guess alot of this stuff will be order from Japan, prices and eta’s would be good, and then I can fone you in the week to place the order!
Robin.
