I am looking into purchasing a Generator to make life easier at Events for myself
Looking for around 2000KW, anyone selling one or any model people would recommend or steer clear of
I reckon 2mw might be overkill
I had a 3kw inverter on my boat but bear in mind this ran on 4 deep cycle 120 amp hour each keisure batteries. Its too much to ask from a car battery/alternator.
Maybe a quiet generator might work better.
Just seen you said generator… Sorry.
it depends what you plan on running off it 2kva generator would just about manage to run a standard kettle, stephill generators are a good make we use them in all our welfare units pretty reliable even under construction site abuse
mark
I’m assuming Simon this is to replace the two for JAE?
Basic requirements are to run
2x urn
2 X fridges
1x microwave
2x strings of 15 bulbs lights
1x dj set up , decks,lights and speakers
Nope this is personal Steve, the other i know needs around 7/8 kw
Oh my bad!
Steven Butler
This Generator needs to power an air compressor for a double air bed, electric blanket and a phone charger. possibly a snack fridge?
don’t forget his blow up doll
Now I’ve realised your cunning plan Si, I think we need one of these too
So I’m on the mission, my first port of call will be researching on camping forums, where the hardened campers will have tried and tested them.
Will report back with any findings.
these are mine so far
Honda - EU20i - 2.0kW Portable Generator
SGS SPI2200
Yamaha EF2000is
Every 10 DB is double the noise, 50 DB- 60 DB is double
Ouch…£…1 & 3
So as I’m only a little blonde female, could you confirm I’ve got this right please Si.
It’s petrol generated, so doesn’t need to be hooked up to the car battery, which I thought it would, it’s quiet, and you run it outside your tent for 13 amp plugs, phone chargers etc. and we could inflate our tent and airbed with it ?
Sounds a good idea as the cars are not parked next to our tents at JAE after set up.
