Looking to get my first GTO
We’ve made a purchase, the one with the coolant leak.
Drove it back (gingerly) an hour down the road last night. Odometer is approx 75,000 miles/ 120,000km, no other issues to my untrained eye whilst driving down/
Lots of coolant was lost on the drive/ overnight. Fluid was dripping under the driver side, below the expansion tank, and from the driver-side wheel arch.
Topped up fluid and started this morning. Big belt squeal, which wasn’t present when viewing or test driving. My first thought was water pump leak/ failure? have yet to start taking stuff off, but didn’t see any record of pump replacement.
If there are any guides for diagnosing coolant leaks on here that people can link me to, would be very much appreciated. I’ve seen lots of posts up, so it seems like quite a common issue.
Congratulations on your purchase.
Regarding the coolant leak if it’s driver’s side look at all the radiator hoses - the lower one especially as that is close to the areas you described.
The water pump is on the passenger side - if you’re changing this do a full timing belt service- can certainly save you a lot of headache later - especially if no evidence of it ever being done.
Just a final comment- perhaps start a new thread in the general or technical sections of the forum as now you have the car you’re no longer a newbie :joy:
Thanks James, will do.
@luke3 if you do get your water leak fixed - it would be great to meet you and your car at one of our events - here is the next one up at Santa Pod:
also we have our Christmas party which you’re more than welcome to attend up in Kegworth:
Thanks James, I am super keen to come down for Japshowfinale if I can get it sorted.
I’m taking a look at the leak on Tuesday together with my mechanic, see if we can figure out what’s what. :+1:
Hi nice purchase there,regarding the leak if its below the expansion tank it could be the expansion tank itself as there is a rubber seal underneath and could have perished,radiator hoses then potentially the heater hoses or the throttle body too the hoses that come out the thermostat housing the fittings are metal and rust over time and leak,best is to remove the battery and tray remove the maf and the y pipe and intake hoses for a better view
Really nice Tahiti Blue MK1 car only made two batches of this colour in 1992 and 1993 quite a rare colour !
Congrates on buying one if you need any parts give me a cool
Regards Rob
Well done @luke3, car looks a beaut. I think you really bought that colour to match the house, only joking mate, enjoy and hope its a quick fix for the water leak.
Makes sense, will defo add this to the to-do list =]
Also check rad cap
If perished it can cause coolant to blow out through expansion tank overflow pipe which comes out below expansion tank
Jensen
