Maft pro harness
hello rob don’t suppose you have a patch harness for the maft pro found this on mine hope its the cause of the problem im having atm fault code showing cas and tdc sensor faulty
http://i242.photobucket.com/albums/ff293/booconstruction/ABCD0011-3.jpglooks like previous owner may have pulled the wires out n tried to solder them back in
Hi Dave,
Send me a E mail and i will send you a pin out of the MAFT Pro to check to see if they are the pins causing your problems.
I can sort your loom out for you too, dont need a full loom
Call me if you have 5 mins
Cheeers Rob
thanks rob will do mate will make a few hrs tomorow n give you a ring :smiley:
