Mark 1 reverse gear
Hi All ,I am after a reverse gear for my 1991 marl 1 my car will no longer go backwards ,I am trying to get a new one but it is proving a bit difficult ? And an gearbox input bearing if poss ;hopefully someone can help in my search ?? Thanks Matt
I have moved this to the newbie section , not insurance :smile:
Should really be in the technical sections but you can’t see those as your not a full member
Craig :slight_smile:
Hi Matt,
To be completely honest mate you may be better off getting a second hand box as i’ve just been quoted £1200 to replace the 2nd and 3rd gear syncro.
Unless of course you know what you’re doing inside a gearbox then @GSXRKID will be more than happy to sort the bits out you need i’m sure.
Good luck mate, hope you sort it out.
