Mk1 Active Aero Trays
Hi Dan,
I only make the mk1 trays as someguy in Germany makes the mk2.
Yes I fabricate the corners for the mk2.
Errrrrm No!
:rofl::rofl::rofl::rofl::rofl:
The MK1 and MK2 GTO trays are exactly the same
Its the GTO and 3000GT that are different and only the 3000GT have the corners on them, apart from that they are the same.
Sorry I mean I don’t make the 3000gt trays, but the corners I do.
Aren’t the access panels different also on the 3000GT?
No Stevie they are the same
The kidney one is the same but I’m sure the two large rectangular covers have two lips on and the small rectangular one is more oval shaped having larger radius corners.
Joe
Were you looking for a set. I have the three bits from a 98 Mk3 N/A
Yes I am looking. Although I’ve got a Mk1 so not sure if they’re the same?
If you pm me your chassis number I can check to see if the part numbers match as a starter. If it is different numbers you are welcome to check on your car first.
