Thought I’ll put a few pictures of my display since I’m a pastry chef
Thought you’d might like to see what I do apart from getting greasy hands😁
Wow Jerry that’s amazi-balls, well done, a huge talent you have there.
Quick question, do you still like chocolate after working with it so much?
Of course who doesn’t like chocolate
I do tend not eat much desserts though as I make them all the time of course unless I do something new then I’ll have to try it to make sure is as it’s supposed to be.
Should Change your name to Choccywookydooda!!
Steve, nearly spat me tea out with that comment, the chocolate stuff however, magic, absolute magic is all I can say.
Looks like we have some entertainment for JAE sorted then
I’m up for that with Colin
That looks amazing but think i would be sick lol
Your very talented mate
just amazing Jerry. such talent
Cheers guys and gals it is a lot of hard work but like anything with passion and commitment you can achieve results.
Crazy Jerry awesome stuff need a demo at JAE!!
great work…
Blimey that’s awesome.
How long did it take to create?!
Over 2 days doing them along the normal day to day duties I’d say about 8/10 hours combined
Big rush this morning had to be at work at 5 am to finish off the decoration as had to be out on display by 9 am
Don’t you find that they start to collapse with the heat? It does look awesome
The worst enemy for a chocolate display or any of the displays I do are the people touching them " they go over and wow is this real chocolate and then oops broken, let’s walk away before anyone seen us"
Heat is a problem but in this country is not too bad
We chefs use a method called “tempering”
Which basically is a method on how to melt chocolate and then when it’s sets it will set hard and that involves heating the chocolate slowly to 43.5 degrees then you cool it down on a piece of cold marble while keep mixing it until comes down to 28degrees and then you warm it again to reach around 31 to 33 degrees depending on the quality of chocolate, then it’s ready to use.(basically like when steel is tempered to make it stronger obviously steel goes up to 2 thousand degrees) same principle though with chocolate.
Basically it’s manipulate the chocolate crystals “we call it”
That way it will set hard that if you try to break it you’ll hear a snap.
You need to know what your doing in the process as if you heat it too much then it won’t set hard and you want have that snap plus the chocolate when it’s set it will be discoloured and horrible.
Same as steel then. Something that’s easily related to me lol.
Difficult but rewarding technique. People wanting to touch things is a type of compliment, but bloodybfristrating as you want to keep it entire as long as possible
As for the chocolate turning funny colour n tasting different, it’s surely the same thing when we see chocolate turned “white” from the shop having let it get too warm?
