Hi and a newbie this is my first GTO its a 91 GTO TT jap import purchased 3 months ago from a mate that has had it 13 years.
first 2 days in my ownership it was great my mate had it on the road a month before i purchased it but after i got it two days in it started to misfire??? now i have spent just over £1000 but still misfires? on tick over its sounds ok but lift the revs a bit it misfires.
things i have done:
swopped injectors
swopped coils
new plugs iridium
new 8mm leads
new plemum / throttlebody gaskets
sent ecu to ecu doctor for as he said needed repairing.
sent ignition amplifier to ecu doctor found ok
dont really know what to do now but have can of petrol ready :x :x
so please if any of you are in the leicester area or know someone with any help or guidance im desperate thank you for reading.
[quote]Hi and a newbie this is my first GTO its a 91 GTO TT jap import purchased 3 months ago from a mate that has had it 13 years.
things i have done:
swopped injectors
swopped coils
new plugs iridium
new 8mm leads
so please if any of you are in the leicester area or know someone with any help or guidance im desperate thank you for reading. :([/quote]
I had a similar problem with my GTO when i got it, so like you I changed the plugs and leads, what i found was a mismatched set of plugs, which is obviously not your problem, BUT one of them was lose in the head. I suggest you just check them all and that the leads are all on properly before buying more parts. It may save you some cash.
Welcome to the club dude… Best thing you could try is undoing or checking all that you’ve done and methodically work through it all. Double check everything… As Brendan says
hi and thank you for the welcome yes have had ecu back and the ecu doctor even sent me a replacement to try
Hi Rob did what you said and cut a v in the plenum backets now runs as it did but still with this misfire also went into everything today to make sure i had not missed any thing i can now replace plugs and leads blind folded with a larger in one hand. theres got to be an answer to this???
Leads, plugs, coil pack, PTU, wiring to all the the above Need to be checked, tested etc.
Most commonly ecu leaking caps.
Are you getting any spark at the coils, have you individually tested each coil to see if one is a problem or not, this is where I normally start and work back for there, just don’t give yourself a big electric shock doing it.
