I have a new Genuine Mitsubishi GTO MR non ABS proportioning valve, plus a set of genuine engine bay hardlines available.
All new, never fitted.
£90
Can bring to Japfest
a proportioning valve is hard to come by same as used on the non abs fto that I used . just add that an abs delete can be done with the engine in place and without removing the rear turbo if anyone is interested not many of us have done this in the past but if anyone is putting there gto on a serious diet its a must really
The FTO valve looks the same, but has a different part number.
I decided not to go for it, as the relative weight of the two cars are so different.
This is the GTO MR one.
Strange as when I enquired I was told exactly the same part oh well it worked. Perfectly once installed. And it did look exactly the same. Removing the various parts its only a few kg,s but it all adds up and I was on a mission to remove as much as possible at the time
Sent from my BlackBerry® smartphone on O2
