Oil cooler lines
Rob,
any chance on all 3 lines that form the oil cooler path? (2 flexi-s and the hard pipe)
the return pipe certainly needs replacement sooner rather than later, as the “crimp” section has a split in it due to corrosion ingress
do they come with new sealing washers for the banjo connections?
discount for all 3 parts :smiley: do need to talk to you sometime about rear camber arms
Hi Simon,
All 3 lines are in stock along with the seals
Give me a call
Cheers rob
Rob,
arrived today
HOWEVER, only one set of 4 of dowty seal washers, need of course 8 to do the job, unless you recommend me re-using some :?
also NO FREE GIFT, i was so dissappointed :lol:
I deffo packed 8 in two packets.
i wonder if they managed to escape from the box if it was damaged at all…??? as they are quite slim…
Will send you out some more with your free gift… :wink: :wink: :wink:
