Output shaft
Hi Rob,
Any news on the shaft, sleeve and other bits i have ordered?
Hi James
Everything is here apart from the shaft and sleeve which should be here today as well…
Will call you when it arrives
Thanks Rob.
Hi rob - still no parts, any news?
Hi James,
I am going to call you and explain…
Too long to write out on here.
If you read this before i have called you, please call me
01702-614469
Its stupidly busy here today!!!
hi Rob
Do you know if UPS are running again as planned? Also did you check on those break disks?
Hi James,
Tried to call you on both the numbers i have for you.
Left you a message on your mobile.
Call me when you have 5 mins tomorrow if you dont catch me today
Hi Rob,
Can you supply the oil seal that seals the output shaft in the transfer case? Also the large rubber bung in the gearbox cover that has to be removed to access the shaft bolt to change over the output shaft. I looks like i wont be able to remove it without destroying it!
Hi James,
Yes i can do both will chuck them in FOC for you
Damn fine chap!
