Hi Rob
My cooling fan is running all the time and looking on the boards it seems it will be the rad switch, have you got one and how much??
Also need a double to single din facia, any idea where I can get one??
And finally I think its time to change the prop mounts, still got some?
Graham
Hi Graham
The Rad Temperature Sensors are £35.00 each and are coded White or Black.
I have the double din Surrounds in stock £12.00
And i also have loads and loads of prop mounts in stock too, £110 a pair
I also have the mounting bushes in stock to £20.00 set
Give me a call if i can help you.
07891-606913
Hi Rob
Have you posted the bits yet? if so they haven’t got to me, can you let me know
cheers
Graham
Hi Rob
Any update on my parts yet?? still not recieved them.
Graham
Hi Graham,
The last piece of your order should be with me tomorrow (Friday) where i will then dispatch it all to you.
Sorry for the delay.
Give me a quick call and i will explain the delay.
07891-606913
No worries Rob, like i said, I was worried that you had sent them and the post office had fitted the bits to one of their vans…
Graham
