hi rob, thanks for your text, man its hard getting hold of you, i will take a spark plug cover, you got any pics? also i need the two o rings for the fuel rail adapter mod, i had an accident putting the one on i bought off you, i never put the two brackets on first, i tried to mount the whole assembly and consequently chewed up the rings as they went in on an angle. can you use same card as b4 and get them to me yesterday? cheers webbo
rob i also need a couple of bolts for the rear engine mounting, it looks apparent that route 66 did not bolt the engine to the mounting, it is just sat on top of it, i can see two bolts missing that go behind and below the plenum and in to what looks to be the head. this mean out to you? do you have these bolts in stock, they sit right next to each other just behind the brake fluid resovoir bottle. cheers neil
ffs!
that is not he half of it james, im thinking of now going to see my solicitor, there are bolts missing everywhere, all the brackets that should be bolted to the engine ie pipes etc are all just hanging loose. the throttle body had 3 different sized headed bolts!!!
If you need any more evidence Webbo give me and Mitsy a shout - you won’t believe some of the things we found on my car!
you aint found any of my missing bolts have you, oh man this is shocking, i think i am just gonna take to mitsu and get it all looked at and sorted.
I’ll trade you some missing bolts for a completely missing front gearbox bracket if you have mine! I also have some oil drain gaskets made of sealant and fresh air, a new mod which means a I no longer require (or have) heatshields. I also have a melted throttle cable if you’re interested?
Or maybe a straight turbo hose that can also be a 90 degree one if you bend it hard enough…
Grrrrr!
Take it to Mitsubishi if I were you - mine could have gone seriously wrong in a short while if Stu hadn’t taken a look at it. My gearbox may actually need rebuilding due to the bracket being missing - should find out this weekend.
Hi Neil,
I have a pic on the Evil Website,but it is down as Lycos have some severe problems at the moment.
I will post the Spark Plug Cover and O Rings out to you for Saturday delivery today and i will sort payment out with you later
[quote]I’ll trade you some missing bolts for a completely missing front gearbox bracket if you have mine! I also have some oil drain gaskets made of sealant and fresh air, a new mod which means a I no longer require (or have) heatshields. I also have a melted throttle cable if you’re interested?
Grrrrr!
Take it to Mitsubishi if I were you - mine could have gone seriously wrong in a short while if Stu hadn’t taken a look at it. My gearbox may actually need rebuilding due to the bracket being missing - should find out this weekend.[/quote]
man thats bad, funny though i have an oil leak, i need to find where its coming from, it never leaked before but as i aint been running it i havent bothered getting it done, bet its silicone!!!
Neil
A Nice white Jiffy bag will be with you in the morning.
cheers pal, will be able to get her fired up then, need car today if poss, save me taking dam van. thanks rob
