Hi I’ve just joined so if I have placed this in the wrong place then let me know just a quick question will this exhaust fit my car and is it worth £70 inc postage for it thanks in advance
It’s a mk1 auto non turbo
It looks like a GTO exhaust and i think i am right in saying that they are all the same that far back. It is the downpipes you need to watch out for as they are all different.
As for its worth… The thing with powerflow is they are a franchise so some will be great quality and some will be terrible. The value seems pretty good but that being said i would imagine it only cost £200-250ish new so may want to consider finding a local powerflow shop (or longlife is a similar set up) and get a quote to get a new one made up. That way you can do your homework on the shop you intend to use and know what you are getting. Contact a couple of local shops and get some quotes and go from there. If none of them work out then it may be worth a punt on that one.
I was only looking really as the last mot was an advisory of slight leak from rear exhaust will have a think no need to rush into buying it just yet cheers
I’ve just had my exhaust all in bits from front to back on my twin turbo. This exhaust looks like it will fit the back of your N/A car more or less, but it looks like you might need another piece of exhaust to connect you up to the cat. I could be wrong but just chucking it out there based on pictures. And the hours I’ve stuck in recently making my exhaust fit right.
