Rear Power steering control valve
Rebuilding the rear subframe assembly next summer so going to refurb the entire assembly if poss. Steering rack, pipes bushes etc. Just wondering if the control valve for the rear power steering is a serviceable part or can be refurbished and made pretty again.
You had better order the subframe bush kit as i only have a few left and i am the only company in the world with stock of the complete kit .a After these kits run out the kit will be an obsolete kit and you wont be able to the overhaul.
Most of the pipes are now also hard to obtain too
Just thought i would let you know before you -pull it apart next year and can replace the parts and wreck the car
Can you send me a link to all the components I need. Thanks for letting me know.
Here you got for the subframe mount kit
These are nearly obsolete !!
https://www.evilempireperformance.co.uk/gto-and-3000gt-rear-sub-frame-mounting-bush-kit.html
Comes up with free postage but says I’m collecting in store? How do I go about getting it delivered to my home address
Have you registered with the website and put your name and address in properly ??
The mini cart is not working at the moment you have to join the website properly
Any problems give me a call 01702-614469
Be needing one of them
Hi Torx
I’m locking this post , all technical questions should be asked in the relevant sections within the boards
Newbie section is for introductions though we do give a little slack for first timers with issues , full access is available through membership which can be purchased through the club shop
Unfortunately as per club rules as voted on by the members of the club any further posts in this section regarding technical issues will be removed
