For sale is a 1997 Uk 3000gt in Red, the car has covered 113k
the car is in good condition having being looked after well by its previous owners. However some parts of the car are showing signs of age, mainly the paint and body.
Good points :
Low mileage for the age of the car.
Engine is perfect, starts first time, and is very quiet (swiss watch quiet), the engine feels good, pulls very well in all gears holding boost with ease.
Cambelt, water pump and tensioner changed by Mitsubishi @ 89k
Gearbox has been recently repaired with a replacement output shaft and replacement transfer case input spool.
Everything electronic works perfectly on the car, ABS, ECS, SRS, A/C, Cruise Control, Active Aero.
Full black UK leather is good apart from the drivers seat bolster.
The car has had lots replacement parts fitted over the last 5 years :
New Clutch fitted by Sumiyaka , 4x DBA discs and EBC Pads, Sumiyaka racing plug leads and plugs, goodridge braided brake lines, Forge Recirculating BOV, brake caliper overhaul, 3rd gen lifters, sumiyaka Cat back dual exhaust system, new mitsubishi Aero tray, New mitsubishi aero motor and linkage, mitsubish wheel bearings X4, new mitsubishi downpipe, headlight washer motor replaced, offside front ABS sensor, new tyres fitted 6k ago. the car has 17" Momo Alloys.
Bad points :
The nearside rear 1/4 panel has a scuff from in front of the rear wheel to behind the rear wheel, also a small patch of surface rust. see pic.
As the car is red the plastics are a little faded, i have t cut the car manually and it has brought it back. i suspect a machine polish will bring it out better than my ageing body!
Offside front wing has some small rust bubbles.
The Alloys have kerb marks.
The drivers seat bolster is worn but not ripped.
Scuffed 1/4
£2750, last chance before ebay
Any questions please ask.
