Rev counter has stopped working
Morning everyone,
I was going to take my car out at the weekend, but found that my rev counter is no longer working, doesn’t move from 0 even when car is idling. Car seems to idle fine, its not lumpy or missing a beat, just annoying the counters no longer functioning
Does anybody have any tips on how I can identify what the cause of the issue is?
Usually ptu that causes rev counter issues.
I would start with that.
There is a way to test them.
Here’s a link.
https://forum.gto.club/t/ptu-required/28617/10
Thank you, will take a look at the PTU, do you think it might be worth giving the plug a clean?
Rev counters can just die for no reason mine has just done that, so try and find a good second hand one if the ptu tests fine
I have a PTU I could send you to test, if its still the same then you could just send it back? :+1:
I had a similar problem with my rev counter, sometimes it showed nothing, and sometimes the reading was too low.
Knowing that all the electronics in our cars suffer from failing capacitors, I replaced the capacitors in the rev counter, and voila!, back to working order.
Unfortunately I cannot remember the values of the capacitors, but it is clearly marked on them.
Thank you, I will take a look at it this weekend and PM you :slight_smile:
hopefully not more capacitors lol,
Thank you for the info :slight_smile: I thought about taking the cluster out and seeing if the wiring was ok but this looks like quite a big job
I have the same issue, pretty sure it will be capacitors - hoping to do the job over the next few weeks, I’ll post here with any luck
did your car sit for a while before this happened?
Taking the cluster out is a piece of cake
From memory so bare with me
There are two screws at the top of the black bezel , remove those and pill the bezel/shroud forward , unclip the electrical connectors and place to one side ( you can see them by looking up )
You will see 4 screws around the outside of the instrument cluster , remove them and voila it will pull forward
Does help if you have the steering wheel lowered too
I think the hardest bit was actually gstting the plastic surround out with the steering wheel in place
Yeah @reece.cambridge, drop the column and its ok.
So interestingly I brought the car to work today, the rev needle moves to about 1k, and that’s as far as it goes, The car doesn’t get used very often, I have probably done about 600Km since May, but car does get started frequently.
I will try and get the cluster out and check behind it :slight_smile: Thank you
