hi rob
do you do the cam rocker cover seals and bolts if so how much?
cheers matty
Never been asked for the bolts, but i have the gasket kits in stock.
http://www.evilempireperformance.co.uk/images/Rocker%20Gasket%20KitWTMK.JPG
http://www.evilempireperformance.co.uk/product_info.php?cPath=30_35&products_id=59
need the washers rubber seals that the bolts go into if you do them ?
hi rob
did you find a price for the front rocker cover rubber washer seals
cheers matty
Hi Matty
Do you mean these…
http://www.evilempireperformance.co.uk/images/GTO%20Cam%20Cover%20Washers.jpg
http://www.evilempireperformance.co.uk/product_info.php?cPath=30_34&products_id=203
If so £2.00 each and they are in stock, you will need 11 per cam cover
